Previous Topic
Next Topic
Book Contents
Create a custom Clintrial context panel
  1. Create a data set for the context panel.
  2. Create a data series for each context item.
  3. On the Properties tab, set the values of custom properties for the data set and each data series, and press Enter.
    Tip Tip: If you don't see the Properties tab, at the top left of the page, select View, and make sure Properties is selected.
  4. Optionally, map items to the data series.
    If you do not map specific items to a data series, the values of the key items are derived from the control path of each InForm transaction as it is processed.
Note: The validation process checks the design of a custom context panel for compliance with Clintrial design rules. However, the Central Designer user interface does not enforce similar checking. Therefore, make sure that your definition of a custom Clintrial context panel does not violate Clintrial design considerations.
Send Feedback
