Create a non-patient data (Type 0) panel
- Create a data set for the non-patient data panel.
Note: Master-detail relationships are not supported in non-patient data panels. If the Detail Key Item, Detail Panel, Master Item, or Master Panel CIS custom properties have values in the data set for a non-patient data panel, validation fails.
- On the Properties tab, set the value of the Panel Type CIS custom property to Non-Patient Data, and press Enter.
Tip: If you don't see the Properties tab, at the top left of the page, select View, and make sure Properties is selected. - Create a data series for each item to include in the panel.
Note: Do not map items to any of the data series in the panel.
