Add an item to a data series by selecting a study event or form
At the study event level, you indicate whether the item is mapped to the data series only when it appears on a specific study event or form.
- In the Project Explorer, select the form or study event containing the item to be added to a data series.
- Select the Data Series Summary tab.
If a form is selected, its items appear in the grid.
If a study event is selected, its forms appear in the grid.
- Optionally, to change your view of the grid, use the filters at the top of the grid.
- In the item's row in the grid, click the cell in the column for the data series to which you want to add the item.
Note: If the item cannot be added to the data series—for example, if the data types for the item and data series are not compatible—None compatible appears in the cell.
- Click the drop-down arrow at the right end of the cell, and select one of the following options from the list:
- None—The item is not added to the data series.
- Always—The item is always mapped to the data series, on every form, in every study, and in the library.
- Form—The item is mapped to the data series only when the item appears on a specific section (or form, if the form has no sections). You can select this option for multiple sections or forms.
- Study Event—(Available only when a study event is selected.) The item is mapped to the data series only when it appears on any form in a specific study event. You can select this option for multiple study events.
- Study Event & Form—(Available only when a study event is selected.) The item is mapped to the data series only when it appears on a specific form in a specific study event.
- If you selected a data series that has custom dimensions, select a value for each custom dimension, or, if providing a user-defined value is allowed, type a value for each custom dimension.
If the item is an integer or float, you can map the normalized value, entered value, or entered unit to the data series.
Note: You can create one data series for each type of value, so you can map the item to three data series (one for each representation of the unit).
- For an integer or float item with a selected unit, select the item representation to map to the data series. You have the following options:
- Normalized value
- Entered value
- Entered unit
- Optionally, add the item to more data series, or add other items to data series.
