What is the difference between an instance and a link?
Differences between instances and links
Type |
Description |
Appearance in the Project Explorer |
Instance |
An actual study object in a study |
Study objects that are instances appear in study object containers. For example, all study elements in the Elements container are instances. |
Link |
A link to a study object in a study. |
Study objects that are links appear as children in study object containers. For example, if a study event is a child of a study element in the Elements container, the study element is an instance, and the study event is a link. |
