What conditions must be met before a study object can be imported?
Pre-import checking verifies that the following conditions are met before ODM is transformed to CSML for import into Central Designer.
- All requirements are met. For more information, see Considerations for ODM import in InForm studies.
- The input file is a well-formed XML file and is fully compliant with the ODM 1.3 schema.
Note: Error and warning messages appear as Job Results on the Central Designer Job tab.
Note: You cannot import a CSML file into a library if the file contains a study design. A CSML file contains a study design if you exported the CSML from a study. To add study objects that are in a CSML file to a library, import the CSML file into a study, use the Libraries tab to search for the study objects, and then drag them to the library.
