Create a global condition
Tip: When you need to apply the same action to multiple study objects, we recommend creating a workflow rule instead of applying a single global condition to multiple study objects. A workflow rule is evaluated only once.
- In the Project Explorer, select a study design (in a study only), study element, or study event.
- In the Workflow Diagram tab, click Global Conditions.
- To the right of the grid, click Add.
- Enter a name and description for the global condition.
- Click OK.
- On the Expression tab, create the rule expression.
- Drag any of the following objects from the tabs on the right to the Expression workspace.
- Data Mappings tab—Data mapping study object, rule model property, method for a global study object.
- Constants tab—Constants.
- Functions tab—Functions.
- Data tab—Value of a study object, a rule model property, or a method for a repeating study object.
Tip: To view the rule model properties of all of the study objects, click Show All.
For more information, see Rule Wizard—Option descriptions.
- Add operators and literals, as needed.
For more information, see Operators and literals in the Rules Reference Guide.
- Click OK.
