Check rule syntax
Check rule syntax to ensure that the code in the rule expression is written correctly.
- In the Project Explorer, select a form, a form template, an item, an item template, or an item type.
- Select the Rules tab.
- In the grid, select a rule, and click Check Syntax.
- Select Show Errors.
- At the bottom of the Rules tab, in the Rule Summary section, resolve any reported errors.
