I delete a rule
For a rule that you no longer want to use with a study, you can delete, deactivate, or disable the rule. The behavior of the rule in the InForm application depends on the action that you choose.
Tip: When deploying to InForm release 6.1.1 or later, you must create a deployment instance in order to see the behavior described in this topic. The deployment instance allows Central Designer to communicate with InForm to determine the rule states and update them accordingly.
When you delete a rule, Central Designer removes the rule from the study. Deleted rules are not validated or deployed to InForm.
- If you deploy to an InForm release prior to release 6.1.1, the rule is not deleted in InForm.
- If you deploy to InForm release 6.1.1 or later, InForm marks the rule as Inactive when you deploy your study. The rule does not appear in the InForm user interface.
Note: If you deactivate a rule in any release of InForm after deployment, it is not deleted in Central Designer. As a result, if you do not delete, deactivate, or disable the rule in Central Designer, the next time you deploy the study, the rule is deployed to InForm in the Active state.
