Generate, save, and print a report
Show me how to generate a report
- In the Project Explorer, select a study object (study design, study element, study event, form, section, item, codelist, codelist item, mapping, data set, or data series).
- Select Actions, then Reports.
- From the Reports drop-down list, select a report, then click Run Report.
Tip: If no reports are available for the study object, the message, There are no reports for the selected object, appears in the drop-down list. - To save the report:
- At the top of the Reports dialog box, click Save As.
- Navigate to the location in which to save the report.
- In the File name field, type the name of the report, and click Save.
The report is saved as a CSV file.
- To print the report, at the top of the dialog box, click Print.
Note: When you generate a report for a study that contains an invalid workflow, an error occurs, and the report cannot be run.
