Step 2b: Add rules to the Safety Case form
When do I do this? After the forms are complete.
Why should I do this? So that safety data can be sent from InForm to Argus.
- (Required) If no adverse events are on the form, issue a query to alert the InForm site user to add an adverse event to the form or delete the entire form if the case is not needed anymore.
 - (Required, if you added a sequence ID field on the Adverse Event form and the Safety Case form has an item for the site user to enter the sequence ID), copy value from Adverse Event form to a Safety Case form.
If you reference exactly where the shared item is, the query will only be generated on the referenced form. Otherwise, a query is sent for both the Adverse Event and Safety Case forms, but will be read only for the Safety Case form and the InForm user will not be able to change the value.
