Coding Dictionary Metadata workspace
In the Coding Dictionary Metadata workspace, you view existing dictionary metadata items and import new dictionary metadata items to overwrite the existing dictionary metadata items. A dictionary metadata item is an identifier that describes administrative data about a dictionary and that you can use to create a coding map.
To open the Coding Dictionary Metadata workspace:
- Click the System Config button.
- Under Coding, click Dictionary Metadata.
Coding Dictionary Metadata workspace - Option descriptions
Option descriptions for the Coding Dictionary Metadata workspace
Field
Description
Display Name
Name of the dictionary metadata item; either Dictionary or CoderName.
Version
Version number for the dictionary metadata item.
Level
Dictionary level for which a coding map can be defined for the metadata item; either Dictionary or CoderName.
Level Type
Information that indicates the type of supported target item for the dictionary metadata item. The only available option is Term.
Description
Description of the dictionary metadata item; either Dictionary or CoderName.
