User Info tab
In the User Info tab of the Users workspace, you can manage user passwords and display names.
To open the User Info tab:
- Click the Users button.
- Select a user.
The Users workspace appears, with the User Info tab selected by default.
User Info tab - Field descriptions
Field descriptions for the User Info tab
Field
Description
User Name
User name for logging on to the Central Designer or Central Designer Administrator application.
Note: You cannot modify a user name after the user has been created.
Display Name
Name that appears in the title bar in the Central Designer application. The Display Name field is searched when you search for a user in the Users Browser in the Central Designer application.
Status
Options are:
- All
- Active
- Inactive
- Terminated
- Locked
Note: You can modify the status of a user in the Users list only.
User must change password at next logon
- Selected—User must create a new password the next time they log on to the Central Designer or Central Designer Administrator application.
- Not selected—User is not required to change the password that you created.
