Targets workspace
In the Targets workspace, you enable and disable available target applications. A target application is an application to which you deploy a Central Designer study. For example, you can use the Central Designer application to design a study and deploy that study to the InForm application. The InForm application is the target application.
To open the Targets workspace:
- Click the System Config button.
- Under General, click Targets.
Targets workspace—Field descriptions
Field descriptions for the Targets workspace
Field
Description
Name
Name of the installed target application.
Version
Installation version associated with the target application. This field is incremented each time a new version of the target application is installed.
Enabled
If selected, allows study objects for the target application to appear in the Central Designer application.
