Reason Text workspace
In the Reason Text workspace, you define the reasons that Central Designer users select when they perform automated deployment operations. Default reason texts are available for all deployment operations, and you can add, modify, and delete texts. Reason texts cannot be edited by users in the Central Designer application.
Each row in the table in the Reason Text workspace displays a reason text for a deployment operation. Multiple reasons can be defined for each deployment operation.
To add, modify, or remove deployment reasons:
- Select System Configuration.
- In the Deployment section, click the Reason Text link.
The Reason Text workspace appears.
- Do one of the following:
- To add a reason text for a deployment operation: In the blank row, select an operation from the drop-down list in the Deployment Operation column, and then enter the reason text in the Reason Text column.
- To modify a reason text for a deployment operation: Edit the text in the Reason Text column for the deployment operation.
- To delete a reason text for a deployment operation: Right-click a row, and select Delete Row.
Note: The reason text must not contain any PHI.
