Right
Permissions
Define and modify study workflow
- Create, modify, and delete study workflows, study elements, and study events.
- Modify properties of study elements and study events in the Properties Browser.
Create InForm forms
- Mark InForm forms as templates.
- Create InForm form placeholders (but not design InForm forms or add items).
- Delete InForm forms.
Copy and link study objects from libraries
- Copy study objects that you have the right to create from a library to the library in which you are working.
- Copy study objects that you have the right to create from a study to the library in which you are working.
Tip: To copy library forms, you also need the Create InForm forms right. To copy library items, codelists, and codelist items, you also need the Design forms, items, and codelists right.
Define, modify and delete Review States
- Create, modify, delete, lock, and protect InForm review states.
Define, modify and delete custom events
- Create, modify, delete, lock, and protect custom events.
Design forms, Items, and codelists
- Create sections, items, codelists, and codelist items.
- Design and modify forms, sections, items, codelists, and codelist items and their properties in the Properties Browser.
- Modify study events in the Study Event Editor > General tab.
Protect study objects in libraries
- Protect libraries and library study objects.
Specify mandatory items
- Mark an item on a form or section as mandatory.
Unprotect study objects in libraries
- Unprotect libraries and library study objects.
