Properties tab—Field descriptions
Field descriptions for the Properties tab
Field
Description
Name
Name of the role.
Description
Description of the role.
Scope
Scope of the role:
- Library—A user assigned to a library role is granted the rights associated with the role only in libraries where that user is also a member of the library team. For example, if a user is assigned to the Librarian library role in the Central Designer Administrator application, the user must be a member of the Librarian library team for a library (in the Central Designer application) to work in the library.
- Study—A user assigned to a study role is granted the rights associated with the role only in studies where the user is also a member of the study team. For example, if a user is assigned to the Rule Creation study role in the Central Designer Administrator application, the user must also be a member of the Rule Creation study team for a study to create rules in the study.
- Application—A user assigned to an application role is granted all of the rights that are associated with the role, without restrictions. For example, a user who has the right to create users can always create users.
Note: You assign users to roles in the Central Designer Administrator application and to study and library teams in the Central Designer application.
For more information about role scopes and the rights they grant, see Rights descriptions.
Approval Policies section
Approval Role
Reserved for future use.
Approval Meaning
