Undoing and redoing one or more actions
You can undo and redo some actions:
- After you perform one or more actions that you can undo, a drop-down menu containing all actions that can be undone appears next to the Undo button. A similar drop-down menu is available for the Redo button.
- After you perform an action that cannot be undone or redone, the drop-down arrows on the Undo and Redo buttons are removed, and you cannot undo or redo any previous action.
Note: If you undo or redo any action except the last one you performed, the action you select and all actions that you performed after it are undone or redone.
