Workspaces and views
The Central Designer Administrator application window consists of:
- Toolbars and a menu bar.
- View pane.
The view that you select (Users, Roles, System Config, or Catalog) determines the information that appears. Some tasks can be performed in the view pane.
- View menu buttons.
When you click a view menu button, the associated workspace appears.
- Workspace.
The appearance of the workspace depends on the view that is selected. Most tasks are performed in the workspace.
- Status icons.
Icons indicate information about the connection between the client computer and the application server computer.
