Previous Topic
Next Topic
Book Contents
Starting the Central Designer client application
The client applications are ClickOnce applications, and you do not need to install them to start them, as you would for applications using a traditional Windows installer.
  1. Using Internet Explorer, navigate to the following address:
    http://<server name>/CentralDesignerInstall
    In the previous address, <server name> is the name of the application server computer.
  2. Click the Start Central Designer Client link.
    The application files are downloaded to a cache and the application is installed. The installation might take some time.
    After the installation is complete, the application opens, and you can log on.
Send Feedback
