Configuring the Cursor Sharing setting for a database instance
When you create a database instance, you must set the Cursor Sharing setting properly to FORCE by running the following SQL command:
ALTER SYSTEM SET cursor_sharing=FORCE SCOPE=BOTH;
Before you upgrade, ensure that the Cursor Sharing parameter is correctly set.
