Required rights for database administrators
The database administrator must create the Central Designer database user before you install the Central Designer application. During the Central Designer installation, you are prompted to enter the user name and password for the Central Designer database user. For more information, see Creating the Central Designer database user.
The database administrator can be any user that has the rights to perform the following tasks:
Task |
SQL |
Automatically executed for |
Create the Database User. |
CREATE USER &1 IDENTIFIED BY &2 DEFAULT TABLESPACE &3; GRANT CONNECT TO &1; GRANT RESOURCE TO &1; GRANT CREATE VIEW TO &1; |
All supported Oracle database software versions. |
Allow the Database User to create function indexes. |
GRANT QUERY REWRITE TO &1; GRANT CREATE SYNONYM TO &1; |
Note: The database administrator user does not have the rights to grant the database user execute privileges on required packages. For information on how to assign the database administrator the necessary rights, see Granting the database administrator the EXECUTE privilege on required packages.
