Install the Oracle database software on the database server
After the database server requirements are met, you can install the Oracle database software. Use the Oracle database software installation documentation as needed. For more information about required Oracle database software versions, see the System Requirements.
Note: If the application server and database server are on the same computer, you must install the Oracle Server software and Oracle Client software in the same home, or the Central Designer server installation will not work.
