Previous Topic
Next Topic
Book Contents
Creating a sample deployment package using the sample study
The Central Designer installation package contains a sample study and units file. You can import the files into the Central Designer application and then deploy the sample study to the InForm application using a manual deployment. Perform the following steps to create a sample deployment package.
Step
Task
More information
1
Import the DesignerUnit.xml file into the Central Designer Administrator application. This file updates custom units of measurement.
Exporting and importing a units file in the Administrator Guide.
The DesignerUnit.xml file is located in the Central Designer installation package in the InstallSupport\Sample Trial folder.
2
Set up locales in the Central Designer Administrator application, and include the following locales for the sample study:
  • English (United States)
  • Japanese (Japan)
  • Czech (Czech Republic)
  • Spanish (Mexico)
Adding and removing a locale in the Administrator Guide.
3
Import the CSML for the sample study into a new study project.
Importing study objects in the User Guide.
The CSML for the sample study is located in the Central Designer installation package in the InstallSupport\Sample Trial folder.
4
Add the locales from step 2 to the study.
Selecting the supported locales for a study in the User Guide.
5
Select all the dictionary types and all their verbatim types on the Coding tab.
Select dictionary types and verbatim types for a study in the User Guide.
6
Validate the study to create a baseline, and choose to ignore the warnings.
Validate a study and create a baseline in the User Guide.
7
Create a deployment package.
Create a deployment package from a validation baseline in the User Guide.
8
Save the deployment package to the local computer.
Saving a deployment package in the User Guide.
9
Copy the deployment package and the public key to a location that is accessible to the InForm server.
No additional information.
10
Perform additional steps in the InForm application to finish setting up the study.
InForm Installation Guide.
Send Feedback
