Design tab of the Rule Test Cases dialog box—Option descriptions
In the Design tab, you write, modify, and delete test cases for rules.
Design tab of the Rules Test Cases dialog box—Option descriptions
Field |
Description |
Grid |
Test Name |
Name of the test case. By default, test cases are named Test<incrementing number>, where <incrementing number> is a number that starts with 1 and counts upward. |
<item name> |
Each item that is used in the rule expression appears as a field. You can provide test values for each item. |
Expected Result |
The expected result of the test case. Multiple fields appear for data-entry rules with multiple actions.
Rule Details tab |
Text representation and description of the rule. |
Site Info tab |
Information appears in this tab when a locale is defined for a study. |
Site name (or mnemonic) |
Name of the site. This information is returned when you use the GetSiteMnemonic() function. |
Site locale |
Drop-down list of supported locales for a study. The selected locale is returned when you use the GetSiteLocale() function. |
Site locale date and time |
Drop-down list for selecting a date and time. The selected date and time is returned when you use the GetSiteTime() function. |
Form Associations tab |
Information appears in this tab if an item path contains an associated form. |
Associated Data View item paths |
If you used data from associated forms in the rule, select the item paths that you used so that the Rule Test Cases dialog box can use the information when running the test cases. |
Test Properties tab |
Properties for the test name, item, or expected result that you point to in the grid. |
Test Description tab |
Optionally, type a description of the test case. |
