Assign Conditions dialog box—Option descriptions
Use the Assign Conditions dialog box to add a global condition to or remove a global condition from a study object in a workflow. In this dialog box, you specify the terms under which the next object in a workflow appears in a study, when the next object in a workflow depends on the outcome of a global condition.
Option |
Description |
Global Conditions |
Available global conditions. |
Assigned Conditions |
Global condition that has been added to the selected study object. |
Add (>>) Remove (<<) |
Assign the global condition to the study object, and remove the assigned global condition. |
Expression box |
Text of the global condition expression. |
If the value is |
Specify how the result of the selected global condition determines the study workflow. Indicates when the next object in the workflow appears in a study:
