What reports can I generate?
You can generate reports to check the progress of work for the following study objects:
- Studies.
- Libraries.
- All study objects in a library.
Reports provide information about study objects, such as:
- Study objects that have been copied from a library to a study and then modified and saved in either the study or library.
- Number of times a study object was copied to a study or library.
- Data-entry rule action/locale combinations in a study.
- RefName paths for all deployed items (InForm controls) in a study.
Note: You can open the Reports dialog box for all study objects. If no reports are available for the study object, There are no reports for the selected object appears in the drop-down list.
List of reports by study object
Study object |
Report |
InForm-specific |
Studies |
Data Entry Rule Actions Report. |
Yes |
InForm RefName Report. |
Yes |
Library Objects Modified in the Study. |
No |
Library Objects Modified in the Library. |
No |
Workflow Rules and Global Conditions Report |
Yes |
Libraries
Number of Studies Containing Library Objects. |
No |
Library Objects Modified in Studies. |
No |
Study objects in a library |
Studies Containing Selected Library Object. |
No |
