CDD data mapping properties
Study object |
Option |
Description |
Item |
Data Label
User-defined string to use for searching on data in the column. Maximum length is 30 characters. This label is included in the CDD data mapping control path definition in the InForm database. For CDD data mappings, it also appears in target CDD data mapping tables that have any of the following key types: Patient to Control, Pivot Patient, Pivot Visit, Pivot Form, and Pivot Section. |
Data set |
Associated Forms |
Names of pairs of forms for which associations have been created. Selecting a pair of associated forms results in the generation of CDD data mappings for that association. |
Target Key Type |
For the following key types, the target key type specifies the composition of the primary key columns of the target table. Each time a component of the primary key changes from the previous primary key submitted, the InForm application inserts a new row in the target table. Primary keys consist of the following DBUIDs and indexes:
Data series |
Pivot Column |
Identifies the column to use as the pivot column, if the key type is Pivot Form, Pivot Patient, Pivot Section, or Pivot Visit. Note: Only one column can be the pivot column, and it must be the first column in the table. |
Target Column Max Length |
Maximum length of a column, in the range 1-255. This property is applicable for columns with a type of STRING. |
