Baselines Browser—Option descriptions
Option |
Description |
Buttons |
Edit |
Edit the name and description of the selected baseline. |
Delete |
Delete the selected baseline. You can only delete a baseline that does not have a deployment package associated with it. |
Ignore Warnings |
View warning messages and either update the study to correct them or indicate that you will ignore the warnings. |
Make Public |
Mark a baseline as public so that other users can view and work with it. |
Show Validation/Hide Validation |
Refresh |
Refresh the display of baselines from the Central Designer database. Job results for baselines that are expanded are also refreshed from the database. |
Save As |
Save the contents of the Baselines Browser to a comma-separated value (CSV) file that can be opened in a Microsoft Excel spreadsheet. |
Columns |
Note: Not all fields appear in the default view. Optionally, you can add the other fields and rearrange the browser view. |
Baseline ID |
Unique identifier of the baseline. |
Date Created |
Date and time that the baseline was created. |
Deployed |
Yes or No, indicating whether the baseline has been processed for deployment. |
Description |
Description of the baseline, updated if you edit the baseline. |
Job ID |
Unique identifier of the job in which the baseline was created. |
Name |
Name of the baseline. By default, the name consists of the string Validation baseline, along with the date and time it was created. |
Public |
Yes or No, indicating whether the validation baseline has been made public. |
Revision |
Revision number of the baseline. The revision consists of three numbers: "Major.Minor.Revision," such as 1.0.2.
Status |
Status of the baseline:
Status Icon |
Icon that corresponds to the status of the baseline. |
Study ID |
Unique identifier of the study for which the baseline is generated. |
Targets |
The target application(s) for which you validated the study and to which you deploy the study. |
Sub-columns |
The following columns are in the grid that appears when you click Show Job Results and expand the results for a job. |
Code |
Unique identifier for the validation error or warning. You can provide the code when submitting issues to Oracle Support. |
Description |
Description of the baseline message. |
Date Created |
Date and time the validation message was created. |
Issue Name |
Type of issue for which the job result is reporting. This field contains a value only if the job result is a validation error on a rule. Options include Rule Name and sometimes Function Name. |
Job Id |
Job Result Id |
Unique identifier of the baseline message. |
Object RefName |
RefName of the study object that is reported in the validation message. This field contains a value only if the job result is a validation error on a rule. |
Object Title |
Title of the study object that is reported in the validation message. This field contains a value only if the job result is a validation error on a rule. |
Path |
Path of the study object that is reported in the validation message. This field contains a value only if the job result is a validation error on a rule. |
Target |
Target application for which you validate the study and to which you deploy the study. |
Type Icon |
Icon that corresponds to the status of the validation type. |
Validation Type |
Type of message:
Warning Ignored |
Indicates if you have chosen to ignore a warning. |
