Workflow Diagram tab—Option descriptions
Option |
Description |
New Element (Study Editor and Study Design Editor only) |
Create a new study element. |
New Event (Study Design Editor and Study Element Editor) |
Create a new study event. |
New (Study Event Editor only) |
Create a new form. |
Global Conditions |
Create a global condition. |
Rule Tests |
Create test cases for a workflow rule. |
Select All |
Select all study objects in the workspace. |
Layout |
Arrange the layout of the workflow diagram by using the following options:
Zoom |
Adjust the size of the workflow diagram by using the following options:
Enable/Disable Workflow |
Enable or disable the workflow. The text on the button changes depending on the workflow state. |
