Study design properties
Properties common to all study objects
All study objects have the following properties.
Property
Description
Description
Description of the study object. The description can have 0-255 characters.
Identifier
Unique internal identifier of the study object.
Locked
When True, the study object is locked.
Modified
When True, the study object has not been saved since the last modification.
New
When True, the study object has not been saved yet. When False, the study object has been saved at least one time.
Protected
When true, the study object is protected. When a study object is protected, you cannot :
- Update or lock it.
- Add child study objects to it by pasting or dragging and dropping.
- Delete its child study objects.
RefName
RefName of the study object. The RefName can have 1-63 characters.
Revision
Revision number of the study object.
Title
Title of the study object. The title can have 1-63 characters.
Version
Version number of the study object. The version number is incremented only when a user explicitly updates it.
Property
Description
InForm properties
Shared Form Block Key
Block key to use for a shared form; used for data transfers to the Clintrial application through CIS mappings. You must use this property if the block key in the Clintrial application is defined as a numeric field. The block key that you specify overrides the internal text block key (CommonCRF) that the Central Designer application creates during deployment from the system RefName of the special visit for shared forms.
Standard properties
Generic Drug Name
Generic name for a drug.
Protocol
Name of the study protocol.
Sponsor
Name of the sponsor of the study.
Sponsor Date
Date specified by the sponsor of the study.
Sponsor Drug Name
Code name given to a drug by a sponsor.
Study Name
Name of the study.
Trade Drug Name
Commercial name of a drug.
