Layout tab options and deployment to the InForm application
The following table lists the options that are available in the right-click menus, toolbar, and form and control styles for the Layout tab. The table describes the effect of each option when the study objects are deployed in the InForm application.
Option |
Sub-option |
Deployment in the InForm application |
Align Caption |
Left, Right, Top, or Bottom |
Specifies the position of the caption relative to the control. Corresponds to the Caption Alignment property. |
Align Question |
N/A |
Control Type |
For codelist items:
For units:
Edit Caption |
Specifies the text of the caption that appears with the control. Corresponds to the Caption property. |
Edit Textbox Size |
For text controls:
For integer controls:
For float controls:
Edit Question |
Question text. Corresponds to the Question property of an item. |
Edit Question Column Width |
Width of the question column. Corresponds to the Question Width property. |
Orientation |
Specifies how the controls included as children of the grouped control are oriented. Corresponds to the Layout property. |
Section Header |
Form or section title. Corresponds to the Title property of a form or section. |
Section Note |
Specifies the text of a note that appears immediately below a form or section heading. Corresponds to the Note property of a form or section. |
Preview Annotated Form |
N/A |
Preview Form |
N/A |
Reset |
N/A |
Remove Caption |
N/A |
IPR Configuration |
Opens the IPR Configuration dialog box so that you can specify a change as an in-place revision. Note: This button only appears when you access the Layout tab for a form through the Visit Schedule Explorer bar. |
