Study Elements editor—Option descriptions
Columns common to all study object editors
All study object editors have the following columns.
Note: Not all fields appear in the default view. Optionally, you can add the other fields and rearrange the browser view.
Property
Description
Icon (first column)
Study object's status.
Description
Study object's description.
Identifier
Unique internal identifier of the study object.
IPR Status
Indicates whether the study object has an IPR configuration.
Published (only in libraries)
Indicates that the study object has been published.
RefName
RefName of the study object.
Note: We recommend that you don't use Conflict for a study event RefName, as there is a default Conflict visit created for InForm.
Revision
Revision number of the study object. The revision number is incremented each time the study object is changed and saved.
Title
Title of the study object.
Version
Version number of the study object. The version number is incremented only when a user explicitly updates it.
Option
Description
Drop point
Data type of the codelist. The data type of a codelist must be compatible with the data type of any items in which it is included.
