Previous Topic
Next Topic
Book Contents
Set Value Action dialog box—Option descriptions
Use the Set Value Action dialog box to set the value of an item based on the outcome of a rule.
Option
Description
Item
Item for which the value is set. You can type a name or drag an item from the Data tab.
Value to set the Item
Value for the item. You can type a value or drag information from any of the tabs.
Reference tabs—Available components
List of the components that are available for use in the rule being defined.
By default, these tabs appear on the right side of the dialog box. When you select a tab, the Reference section appears, with tabs along the bottom edge.
Data tab
The available study objects appear in a tree structure similar to the Project Explorer.
Functions tab
The available functions appear in a tree structure organized by class.
Note: Functions are defined in the Study Editor or Library Editor.
Constants tab
The available constants appear in a tree structure organized by class.
Note: Constants are defined in the Study Editor or Library Editor.
Data Mappings tab
The components of the available mappings appear in a tree structure similar to the Project Explorer.
Show All checkbox
When selected, all available study objects as well as their properties appear. When not selected, only the available study objects appear.
Send Feedback
