Jobs Browser—Option descriptions
Note: Not all fields appear in the default view. Optionally, you can add the other fields and rearrange the browser view.
Option |
Description |
Buttons |
Hide Job Results/ Show Job Results |
Refresh |
Refresh the display of jobs from the Central Designer database. When you refresh, the job results for expanded jobs are also refreshed. |
Save As |
Save the contents of the Jobs Browser to a comma-separated value (CSV) file that can be opened in a Microsoft Excel spreadsheet. |
Jobs Since |
Drop-down list specifying how far back the display of job results goes. |
Columns |
Finish Time |
Date and time at which the job ended. |
Job State |
Run status of the job, either Started or Finished. |
Job Id |
Unique identifier of the job that generated the listing. |
Job Result |
Indicates whether the job scheduler ran successfully for the specified job. This field is not an indication of the status of the job.
Name |
Name of the job:
Start Time |
Date and time when the job started. |
Status |
Overall status of the job results for the selected job.
Status Icon |
Icon that corresponds to the status of the job. |
Study Id |
Unique identifier of the study for which the job was run. |
Type |
Type of job, either Import, Validation, or BuildDeploymentPackage. |
Sub-columns |
The following columns are in the grid that appears when you click Show Job Results and expand the results for a job. |
Code |
Unique identifier for the validation error or warning. You can provide the code when submitting issues to Oracle Support. |
Date Created |
Date and time the message was generated. |
Description |
Text of the message. |
Issue Name |
Type of issue for which the job result is reporting. This field contains a value only if the job result is a validation error on a rule. Options include Rule Name and sometimes Function Name. |
Job Id |
Job Result Id |
Unique identifier of the job result. |
Object RefName |
RefName of the study object that is reported in the job result. This field contains a value only if the job result is a validation error on a rule. |
Object Title |
Title of the study object that is reported in the job result. This field contains a value only if the job result is a validation error on a rule. |
Path |
Path of the study object that is reported in the job result. This field contains a value only if the job result is a validation error on a rule. |
Target |
Target application for which you validate the study and to which you deploy the study. |
Type |
Type of message:
Type Icon |
Icon that corresponds to the type of message. |
Warning Ignored |
True or False, indicating whether you have chosen to ignore the warning message for the purpose of performing additional processing. |
