Deployment Editor—Option descriptions
Note: Not all fields appear in the default view. Optionally, you can add the other fields and rearrange the browser view.
Option |
Description |
Buttons |
New Package |
Create a deployment package from a validation baseline by using the Create Deployment Package Wizard. |
Save as |
Deliver a deployment package to a location from which it can be deployed. Available for deployment packages created in Central Designer release 2.1 and later. |
Delete |
Delete a deployment package. |
Deployment |
Columns |
Select the columns to display in the Deployment Editor. |
Refresh |
Refresh the display of deployment packages. |
Columns |
Apply to All Sites |
Apply the study version to all sites that use the study. |
Base Layout |
Layout that was created in the Central Designer 1.3 release or earlier and is used with a multilingual study that was deployed to the InForm 4.7 release or later. |
Baseline |
Name of the validation baseline on which the deployment package is based. |
Contains IPR |
Indicate that the study contains in-place revision changes. |
Deployment Counts |
Number of deployments performed for the deployment package. |
Description |
Description of the deployment package. |
Main Layout |
Primary layout that appears if a layout is not specified. |
Name |
Name of the deployment package. |
Package Created By |
User name of the user who created the deployment package. |
Package Creation Date |
Date and time when the deployment package was created. |
Targets |
The target application(s) for which you validated the study and to which you deploy the study. |
Type |
Type of deployment package:
Version |
Version of the study that you are deploying. |
