IPR Configuration dialog box
Use the IPR Configuration dialog box to configure the settings of an in-place revision.
The dialog box is read-only if you do not have the right to make in-place revisions, or if the object or in-place revision is locked or protected.
IPR Configuration dialog box—Field descriptions
Option |
Description |
Description of the change |
Description of the change. Optional. |
Add |
Open the Add Deployment Instance dialog box to add a deployment instance. |
Remove |
Remove the selected deployment instance. |
Refresh Versions |
Retrieve the latest study version information for the selected deployment instance. |
Apply to All |
Apply a change to all study versions. |
Copy Association |
Open the Copy IPR Configurations dialog box to copy the in-place revision association from the selected deployment instance to another deployment instance. |
View Differences |
Open the View Differences dialog box to compare the latest version of the object with the object from a selected study version. |
Columns (Select a deployment instance section, at the top of the dialog box) |
Deployment Instance |
RefName of the deployment instance. |
Type |
Server type for the deployment instance:
Description |
Description of the deployment instance. |
URL |
URL address of the deployment instance. |
Columns (Select study versions section, at the bottom of the dialog box) |
Checkbox |
When selected, associates the change to the study version on that row. |
InForm Study Version |
InForm study version. |
Deployed |
Indicates whether the study version was deployed to InForm. |
