Deployment Package History dialog box—Option descriptions
Option |
Description |
Buttons |
Cancel Request |
Cancel the selected deployment request. Available only if the deployment request has not been approved or rejected yet. You cannot cancel a request if the deployment does not require an approval. Note: Cancelled deployment requests are not archived. |
Cancel Deployment |
Cancel the selected deployment. Available only if the deployment status is Scheduled or Submitted. |
View Log |
Open the deployment log for the selected deployment. Available if the deployment status is either Succeeded, Failed, or Canceled. |
Save as |
Open the Save as dialog box to save the deployment package as a zip file. Available only for deployment packages created in Central Designer release 2.1 and later. |
Export |
Save the deployment package history to a comma-separated value (CSV) file that can be opened in a Microsoft Excel spreadsheet. |
Columns |
Select the columns to display. Not all columns appear in the default view. |
Filter by Deployment Id field |
Enter a Deployment Id to display information only for that deployment. |
Fields |
Package |
Name of the deployment package. |
Baseline |
Name of the validation baseline on which the deployment package is based. |
Package Type |
Type of deployment package:
Columns |
Additional Information |
Additional information provided in the deployment request. |
Approval Required |
Whether the deployment of the package requires approval. |
Approval Status |
Approval status for the deployment request. One of the following:
Archived |
Whether the deployment package is archived. |
Date Completed |
Date and time when the deployment process completed. |
Date Performed |
Date Started |
Date and time when the deployment process started. |
Deployment Id |
Unique identifier of the deployment. |
Deployment Instance |
RefName of the deployment instance to which the deployment package was deployed. |
Deployment Option Type |
Deployment Status |
Deployment status for the deployment request. One of the following:
Deployment Type |
Type of study server to which the deployment package was deployed. One of the following:
Deployment URL |
URL address of the deployment instance. |
Has IPR |
Indicates that the deployment contains in-place revision changes. |
Is Immediate |
Whether the deployment schedule option selected in the deployment request was Immediate. |
Performed By |
Project |
Name of the project containing the study. |
Reason for Deployment |
Reason for deployment provided when the deployment request was created. |
Schedule |
Date and time when to perform package deployment. Configured when the deployment request was created. |
Status URL |
URL used to query for the deployment status of the study. |
Study |
Name of the study for which the deployment package was created. |
