System settings tab of the Administration editor—Option descriptions
Field |
Description |
AutoAnswerManualQueries |
Whether the InForm application automatically answers a manual query when a data item change satisfies the rules on the data item. |
EmailForNewSiteAndUser |
Email address of an administrator who receives notification when a new site or new user is added. |
EnforceVisitDate |
Whether to require the use of Date of Visit on the first form of every visit. |
EnrollWithIncompleteForms |
Whether an InForm user can override a failed screening and enrollment. |
FormSaveMode |
Location and format of the message that appears when a form is submitted successfully. |
InlineDuration |
Number of seconds that the "Form submitted successfully" message remains visible in the header of the form before it fades. Must be a value from 1 to 9. |
NavigationMode |
Whether to allow users to change the order in which subjects appear in the InForm UI. |
PatientSequence |
Format for assigning subject numbers (read-only). |
QueryMaxLength |
Maximum number of characters of query text. Maximum characters: 350. |
QuerySelection |
State in which queries are created. |
RequireCommentsForNA |
Whether a comment is required when NA is used. |
ScreeningSequence |
Sequence number format for assigning screening numbers (read-only). |
SponsorEditFrozen |
Whether a sponsor can edit a form after it is marked frozen. |
TrialDateFormat |
Format of the date that appears in the study |
UniqueIntDOBSwitch |
Requirements for a subject initial/date of birth combination settings.
UniquePatIDSwitch |
Requirements for a subject ID.
UserNameOrder |
Order in which subjects appear in the Signature Details view. |
ViewCRFSignList |
Whether a list of required signatures is included on each form. |
VisitCalculatorEnabled |
Whether to enable the visit calculator. |
ShowUnscheduled |
Whether to show the word Unscheduled in the visit title of unscheduled visits. This setting is only applicable to studies that are deployed to InForm release 6.2 or higher. |
FreeCommentTextBox |
Whether to enable a text box where users can enter a comment for a form or item. If you select Yes for RequireCommentsForNA, you can't select No for FreeCommentTextBox. If you select No, existing comments appear as read-only text, and the option to select Not Applicable, Unknown, or Not Done in the Reason incomplete field is available only for forms and items without data. This setting is only applicable to studies that are deployed to InForm release 6.2 or higher. |
ItemsetUnsvRequired |
Whether to specify when to set a Verified itemset to Not Verified in InForm.
SVAutoSelectRate |
Percentage of subjects that will be automatically selected for Partial SDV. The default is 100. |
SVFirstNSubjects |
Default value for the first n number of subjects that will be automatically selected for Partial SDV. The default is 0. |
SVDefaultInclude |
Include or exclude subjects from the SDV pool by default. The default is Include. |
Note: The system default settings that represent 100% SDV are:
SVAutoSelectRate = 100
SVFirstNSubjects = 0
SVDefaultInclude = Include
The SVAutoSelectRate percentage starts after the SVFirstNSubjects is fulfilled.
