IPR History dialog box—Option descriptions
Option |
Description |
Buttons |
Show IPRs |
View a list of in-place revision changes for the selected baseline. Note: You can only view the in-place revision changes for a baseline for a study that was deployed to the InForm application using automated deployment. |
View Configuration |
View the in-place revision configuration for the study object that you select in the bottom of the dialog box. |
Fields at the top of the dialog box |
Baseline |
Baseline for a study that was deployed to a LIVE deployment instance with in-place revision changes. |
Package Name |
Deployment package name. |
Deployment Date |
Date when the study was deployed. |
Fields at the bottom of the dialog box |
RefName |
RefName of the study object that was modified using an in-place revision change. |
Type |
Study object type. |
Deployment Instance |
Type of deployment instance to which the study was deployed. |
Description |
Description of the in-place revision change that was made to the study object. |
