Create Deployment Package Wizard—Administration data deployment package
Create Deployment Package Wizard—Full deployment package
Page |
Option |
Description |
Welcome |
Introduction page. |
Select a Deployment Package Type |
Specify the type of deployment package to create. Note: To deactivate a rule in the InForm application, do one of the following in the Central Designer application before creating a new deployment package:
Rule-related changes that you make in the InForm application are overridden when you install a new deployment package. Note: If you create or modify a coding map, use a full deployment package to deploy the changes. Changes to coding maps are not supported in incremental deployment packages. |
Full package |
Deployment package that contains everything needed to deploy a complete study. |
Incremental package |
Deployment package that contains everything needed to deploy a complete study, plus additions and changes to the study, reflected in Alternate forms in the InForm application. Alternate forms are not created when you install an incremental deployment package that contains additions to repeating forms or fixed repeating sections (Repeating Data itemsets in the InForm application). |
Administration data |
Deployment package that contains only study administration data. |
Custom events |
Deployment package that contains one or more in-place revisions on custom events. Note: The Custom Events option is for updating existing events. You cannot use it to add a new custom event to a study. |
Select a Baseline |
Specify the baseline to use for creating the deployment package. Validation baselines with a status of Valid or Valid with Warnings are eligible. Note: If you select an unpublished validation baseline, the baseline is made public during deployment package creation. |
Please select a baseline |
Drop-down list of validated baselines available for creating a deployment package. |
Specify a Name and Description |
Specify a name and description for the deployment package. |
Please specify a name for your deployment package |
Name of the deployment package. |
Package description |
Description of the deployment package. |
Ready to Create Deployment Package |
View a summary of the deployment options selected in the wizard. |
Options summary |
Summary of options selected for the deployment package. |
