Translate a codelist item label
You can translate the text of a codelist item label into the languages and locales with which you have been associated in your skills profile. An administrator sets up this profile in the Central Designer Administrator application.
- At the bottom of the Project Explorer, click the Items (
) button, and expand the InForm Items folder. - Select a codelist item.
- On the Design tab, in the Language column, click the arrow that appears when you move the cursor over the far-right side of the cell in the first available row, and select the locale for which to translate the codelist item label.
- In the Label column, type the translated text for the codelist item label.
- Press Enter, or click the next row.
