Add a user to a library team
Pre-requisite: A Central Designer administrator must add the user to the corresponding library role in the Central Designer Administrator. For example, to create rules in a library, a user must be assigned to the Rule Creation library role in the Central Designer Administrator and the Rule Creation library team for the library.
- In the library project, at the bottom of the Project Explorer, click the Library Information (
) button. - Select the library, and select the Teams tab.
- In the [Study name] - Teams section, select the team to which you want to add the user.
- Click the Users tab, which appears on the right of the page by default.
Tip: If you don't see the Users tab, at the top left of the page, select View, and make sure Users is selected. - Do one of the following:
- Click Find.
- Select the user that you want to add, and drag the user to the section at the right.
