Protect a library and all its objects
- In the library project, at the bottom of the Project Explorer, click the Library Information (
) button. - In the Project Explorer, right-click the library, and select Protect.
Tip: If any study objects in the library are locked, you must unlock them before you protect the library. The error message tells you which objects are locked.
