I can't archive a library or library project
If you can't archive a library or a project, one of the following might be the cause:
- The project might contain studies for which you are not a team member.
Solution: Contact a Central Designer administrator to get access to the hidden studies.
- You are attempting to archive the System Library project.
Solution: This project cannot be archived or deleted.
