Publish, republish, or unpublish a library to make its objects available to copy into a study
- In the library project, at the top of the Central Designer window, click File, and select Save Project.
- In the library project, at the bottom of the Project Explorer, click the Library Information (
) button. - Do one of the following:
- To publish—In the Project Explorer, right-click a library, and select Publish Study, then select Publish.
- To republish—In the Project Explorer, right-click a library, and select Publish Study, then select Republish.
- To unpublish—In the Project Explorer, right-click a library, and select Publish Study, then select Unpublish.
- If prompted, confirm the action you want to take, and click OK.
