Create an item group and add items to it
Tip: Group items based on access rights. For example, you can create a group of items to hide from users' view or a group of items to make read-only for a group of users. For more information, see the InForm documentation.
Pre-requisite: A form designer must create all of the items for a study before you can group them into item groups.
- At the bottom of the Project Explorer, click the Study Information (
) button. - Expand the study folder, and select Administration.
- Select the Item Groups tab.
- In the top-left corner of the tab, click the Create item group(s) icon.
- Enter a group name and description for the new item group.
- Click Add.
- In the Item Group—Add Items dialog box, select the items to include in the group.
Optionally, you can search for specific items.
- Click OK.
Tip: To select all of the items in the list, click the checkbox in the column headings. - Click Create.
The item group you added appears in the top grid of the Item Groups tab. Its associated items appear in the bottom grid.
- Next, create a rights group and add item groups to it.
