Export study administration data for use in a user management tool
- At the bottom of the Project Explorer, click the Study Information () button.
- Right-click the study, and select Export Study.
- In the Export Data wizard, click Next, and on the Export Type page, select Administration data.
- Click Next to progress through the wizard, and Finish to export the study administration data.
For more information, see Export Wizard options
Pages in the Export Wizard
Page
Option
Description
Welcome
Introduction page.
Export Type
Select the output format and export type.
Data Type
CSML—Export in Clinical Study Markup Language format.
ODM—Export in Operational Data Model-compliant format. The Central Designer application supports the ODM 1.3 standard.
Administration data—Export only study administration data for the User Management Tool application.
Export Type
Local—Export to the computer where the Central Designer application is installed.
Export File Path
Export Directory
Specify the path name and file in which to save the export file, or click Browse to browse for the path name and file in which to save the export file.
Ready to Export Central Designer Data
View a summary of the parameters that will be used for the export.
