What is the difference between a template and a type?
Characteristics of templates and types
Characteristic |
Templates |
Types |
Purpose |
To provide predefined information about a study object. You are not required to base new study objects on templates. |
To provide predefined information about an item. When you create an item, you must choose a type on which to base it. |
You can create templates and types for the following study objects |
Study projects, studies, study elements, study events, forms, items, codelists, and mappings. |
Items only. |
How to create study objects from a template or type |
Creating a study project or study: You are allowed but not required to choose a template. Creating all other study objects: To create a study object based on a template, find the template in the Libraries tab and then copy it to your study. |
Creating an item: You must choose an item type. |
