What is a template?
Characteristics and descriptions of templates
Characteristic |
Description |
Definition |
A template is study object that is either partially or fully defined and that can be used to create other study objects. |
Available for |
You can create templates for the following study objects:
Purpose of study templates |
Study templates can decrease the time and effort required to build a study. Think about how to set up study templates to minimize work that users might need to perform. For example, you might create templates for different therapeutic areas, compounds, devices, and biologic areas. |
After creating |
After you create and publish a template, users can create study objects from the template. You do not need to publish study project templates and study templates to make them available. When you create a study object, you can (but are not required to) create it from a template. |
History links |
A study object created from a template inherits the characteristics of the template but has no history link to the template. Therefore, changing the template does not affect the study object, and the reverse is also true. |
Versions |
Templates do not have versions; therefore:
Where to view templates |
Study project and study templates are viewable when you create a study project or study. You can view all other templates in the library project in which they are created in the following places in the Project Explorer:
Rule templates |
You can also create rule templates. |
Note: You can protect templates and types. However, if you create a new study object from a protected template or type, the newly created study object is not protected.
