Lock or unlock a data-entry rule
A lock is automatically applied when you begin editing a rule and is released when you save the rule. If you want to work on a rule for an extended period of time, you can explicitly lock it to prevent others from working on it.
- In the Project Explorer, select the study object on which the data-entry rule has been created.
- Select the Rules tab.
- To explicitly lock a data-entry rule, right-click the data-entry rule, then select Lock.
- To unlock a data-entry rule that you explicitly locked, right-click the data-entry rule, and select Unlock.
